Enables logging to all remote syslog host targets.
Disabled.
Configure the syslog host to accept and log messages.
Enable remote logging by using the enable syslog command.
Configure remote logging by using the configure syslog command.
When you use the enable syslog command, the exporting process of the syslog begins. This command also determines the initial state of an added remote syslog target.
The following command enables logging to all remote syslog hosts:
enable syslog
